Good day,
Can you help me correct erase (set Zero) in every case of array.
Array it seems to me very big for PLC cycle. About 500 , 500 LREal.
How possible correct erase all array? Because i try use For Cycle in main program and my plc lose connection.
And second question possible this array save like Recipe ? I tried it and sometime correct worked sometimes not working, but plc dont lose connection like in first case.
Good day,
You could try the MemUtils library function Memset()
Might be safer to pack the array into a function block and call instance_name.FB_INIT()
If they take too long, you might have to do it over several scans, have a xDone flag.
I think Function from library i can not define in program.
What my mistakes, help please?
Try this documented library
https://help.codesys.com/webapp/m0ZSKwt ... n=3.5.15.0
Try using the input wizard.
Might need the namespace in there, so MEMUtils.MemSet
