Codesys RTE 3.5.14.0 und KNX
hufgardm
2019-01-17
2019-01-21
  • hufgardm - 2019-01-17
    ich versuche verzweifelt auf der Codesys RTE 3.5.14 den KNX Stack zum Laufen zu bringen.
    ist ein Eintrag in der Control.cfg nötig, und wenn ja wie?
    Hier meine Control.cfg:
    Zitat:
    [CmpRouter]
    0.MainNet=ether x
    [ComponentManager]
    Component.1=CmpDrvSchedulerAMP
    Component.2=CmpCodeMeter_legacy
    ;Component.3=CmpSJACanDrv
    ;Component.3=CmpEt100Drv
    ;Component.3=CmpEt1000Drv
    ;Component.3=CmpRTL81x9Mpd
    ;Component.3=CmpRTL8169Mpd
    ;Component.3=CmpSercos3Master
    Component.3=CmpHilscherCIFX
    Component.4=CmpKNX'Stack
    [CmpLog]
    ;Log to file
    Logger.0.Name=PlcLog
    Logger.0.Enable=1
    Logger.0.MaxEntries=1000
    Logger.0.MaxFileSize=50000
    Logger.0.MaxFiles=5
    Logger.0.Backend.0.ClassId=0x00000104
    [CmpApp]
    ;Bootproject.CreateOnDownload=0
    Application.1=Application
    [CmpTargetVisuStub]
    Program="CoDeSysControlStaticTV.exe"
    CommandLine=-r targetvisuextern.cfg
    [CmpHilscherCIFX]
    ;TraceLevel=0xFFFFFFFF
    InterruptMode=0
    DMAMode=1
    DynamicFirmware=1
    BootloaderFile=$Firmware$/HilscherCIFX/Firmware/NETX100-BSL.bin
    FirmwareFilePath=$Firmware$/HilscherCIFX/Firmware
    ;non-dynamic declaration of FW-files:
    ;Device.0.BootloaderFilePath=$Firmware$\HilscherCIFX\Firmware\NETX100-BSL.bin
    ;Device.0.Channel.0.FirmwareFile=$Firmware$\HilscherCIFX\Firmware\cifxcom.nxf
    [SysFile]
    PlcLogicPrefix=1
    PlaceholderFilePath=C:\Program Files\3S CODESYS\CODESYS Control RTE3, $Firmware$
    [CmpOPCUAServer]
    UseLoopback=1
    ;NetworkPort=4841 ;Configure the port used by the OPC UA server. Default: 4840
    ;NetworkAdapter=eth0 ;Configure the name network adapter to be used by the OPC UA server. By Default OPC UA will bind to ANY adress.
    [CmpOPCUAStack]
    ;TraceLevel=0x28 ; Set the trace level. Select out of the following values. Add them to select multiple values.Content 0x1, Debug 0x2, Info 0x4, System 0x8, Warning 0x10, Error 0x20, Datetime 0x80, Mutex 0x100, Semaphore 0x200, Memory 0x400, Socket 0x800
    ;TraceEnabled=1 ;Enable tracing of OPC UA component. Select 0 to disable and 1 to enable tracing
    [CmpCAAStorage]
    Memsys5SizeInMB=16
    [SysFileMap]
    PlcLogic/visu/element-bardisplayimage-gray-vertical.svg=0xF99, 0x993D6AC7, 993D6AC7.svg
    PlcLogic/visu/element-meter-meter180-yellow-top.svg=0x1485, 0x77343677, 77343677.svg
    PlcLogic/visu/element-lamp-lamp1-green-off.svg=0x2198, 0x59B773CA, 59B773CA.svg
    PlcLogic/visu/element-lamp-lamp1-green-on.svg=0x258B, 0xEBAB830F, EBAB830F.svg
    PlcLogic/visu/browsercontrol_ext0.js=0x790, 0xB3A69D1C, B3A69D1C.js
    PlcLogic/visu/application.imagepoolcollection.csv=0x7432, 0x7D1392B2, 7D1392B2.csv
    PlcLogic/visu/alarmmanager.tl_alarmstatus.txt=0x26B, 0x44800B5C, 44800B5C.txt
    PlcLogic/visu/recipe_management.tl_recipemanager.txt=0x228, 0x23B4E063, 23B4E063.txt
    PlcLogic/visu/visuelem3dpath.globaltextlist.txt=0xC, 0xD0FBFE54, D0FBFE54.txt
    PlcLogic/visu/navigationspanel_ohnerand.svg=0x1CA08, 0xCF7515E2, CF7515E2.svg
    PlcLogic/visu/visuelemsalarm.tl_alarmtablecolumntitles.txt=0x50F, 0x9EF17450, 9EF17450.txt
    PlcLogic/visu/visuelemsdatetime.tl_datetime.txt=0x9A, 0xBCEEAFCB, BCEEAFCB.txt
    PlcLogic/visu/element-lamp-lamp1-blue-off.svg=0x219A, 0x3DDAEC25, 3DDAEC25.svg
    PlcLogic/visu/element-lamp-lamp1-blue-on.svg=0x24F3, 0xF1E40331, F1E40331.svg
    PlcLogic/visu/element-lamp-lamp1-yellow-off.svg=0x2191, 0x1E343F9A, 1E343F9A.svg
    PlcLogic/visu/element-lamp-lamp1-yellow-on.svg=0x257D, 0x49B8FB1E, 49B8FB1E.svg
    PlcLogic/visu/element-lamp-lamp1-red-off.svg=0x2027, 0xB87B47E3, B87B47E3.svg
    PlcLogic/visu/element-lamp-lamp1-red-on.svg=0x25B8, 0x9C3B1018, 9C3B1018.svg
    PlcLogic/visu/globaltextlist.txt=0xB73, 0xBE286BBB, BE286BBB.txt
    PlcLogic/visu/webvisu.js=0x31E83, 0xCCAC2390, CCAC2390.js
    PlcLogic/visu/webvisu.htm=0x363, 0x86F00840, 86F00840.htm
    PlcLogic/visu/webvisu.cfg.json=0x155, 0xAAB19242, AAB19242.jso
    [CmpSecureChannel]
    CertificateHash=ef305fa124b61b06dcc0983671490687c92dca36
    Habs in allen Varianten ausprobiert.
    Sobald ich ein KNX-Gerät in meinem Projekt einfüge, kommt folgende Fehlermeldung:
    Zitat:
    Fehler beim Download:
    17 unaufgelöste Referenzen, 0 Signaturenkonflikte, 0 Versionskonflikte gefunden
    im Meldungsfenster stehen dann Variablen wie KNX_INIT usw.
    wäre toll wenn jemand eine Idee hätte.
    Danke.
    Tschau
    Marcus
  • herbert.hoefkes - 2019-01-17
    Moin
    Da ist ein „Hochkomma“ hinter das KNX in der CFG Datei gerutscht
    Mach das bitte weg.
    Gesendet von iPhone mit Tapatalk
    Danke für die Info. Ist mir aber schon aufgefallen und habe es ohne das Hochkomma versucht. Leider ohne Erfolg.
    Danke
    Tschau
    Marcus
    eschwellinger - 2019-01-18
    Hallo Marcus,
    ähm sorry ja, KNX ist in der Control RTE nicht eigebaut, du solltest Control Win nehmen.
    Für KNX bracuht man ja nicht wirklich ein Echtzeitsystem.
  • hufgardm - 2019-01-21
    Hallo Marcus,
    Halo Edwin,
    laut der Versionshistorie von Codesys RTE SL V 3.5.14.0 schon:
    Zitat:
    Version .zip with packed Setup.exe (32 and 64 bit) .zip with unpacked Setup (32 and 64 bit) Release Note
    Release date
    3.5.14.0 3.5.14.0 packed 3.5.14.0 unpacked
    Includes security fixes 2018-07, 2018-10, 2018-11, 2018-13, 2018-14
    New feature: CODESYS KNX SL support
    OPC UA: Simplified access to complex types
    17.12.2018
    Hab auch ein Profinet Master an der Steuerung laufen, die schon Echtzeit sein sollte.
    Danke.
    Gruß
    Marcus
    eschwellinger - 2019-01-21
    Hallo Marcus,
    ich finde das nirgends:
    "Version .zip with packed Setup.exe (32 and 64 bit) .zip with unpacked Setup (32 and 64 bit) Release Note
    Release date
    New feature: CODESYS KNX SL support"
    Wo steh das genau, das ist definitv falsch in der RTE ist das nicht verbaut!!?
    Hallo Edwin,
    im OnlineShop unter Downloads:
    https://store.codesys.com/codesys-contr ... 0Versionen
    Dann muss ich mich wohl nach einer alternative umschauen.
    Funktionierts mit "CODESYS Control for PFC200 SL" auf ner Wago PFC200?
    Danke für Deine Hilfe.
    ja PFC100 und PFC200 sollten gehen...
